Activity › Forums › Adobe After Effects › FPS dropping dramatically on .mov in AE
  • FPS dropping dramatically on .mov in AE
    Posted by Josh Bowman on September 8, 2013 at 8:57 pm
    Hi everyone, this forum has been invaluable to me as a lurker over the last year I’ve been learning AE. However, I am having a problem I couldn’t find a solution for, even after asking the Google. I have a screen recording of a mac desktop made with QuickTime, and the frames are fine in that original video. The moment I import it into After Effects the FPS drop down to about 4, and no matter what I do, that’s how it exports also. I have examples here:
    https://youtu.be/smjObw-3ppY?t=5s (Original no problems)
    https://youtu.be/RRI-BrB0T_M?t=5s (After I converted it to an MP4 in AE. The file format doesn’t seem to matter, I always get the same result.)
    I’m sure its something I’m not doing/doing incorrectly but after 3 hours of trying everything I can think of and about an hour looking online, I just can’t figure it out. Thanks in advance for any help!
    Josh Bowman replied 13 years ago 2 Members · 2 Replies
  • Erik Waluska
    September 8, 2013 at 10:11 pm
    It sounds like the codec isn’t playing well with AE. Try converting to a different, less compressed format before importing into AE. Depending on the format you choose, the file size may be huge but at least it should work in AE. Quicktime animation or a PNG sequence are safe bets. You can probably just export from Quicktime or use adobe media encoder or another coversion app.
    Erik Waluska
    EAWmedia
  • Josh Bowman
    September 8, 2013 at 10:37 pm
    I would have kicked myself if it had been that easy, though at this point I’d rather kick myself than keep struggling. I converted it with Media Encoder and again (for a second copy) with VLC, and neither worked unfortunately. Using Media Encoder, the final product had really low FPS (like before). When I used VLC, it seemed to work fine until I imported it into AE, where the FPS slowed dramatically again. Thanks though!
