Activity Forums Apple Final Cut Pro Legacy FPC7 project takes an hour to open
  • FPC7 project takes an hour to open
    Posted by Michael Fasman on January 9, 2012 at 2:09 am
    My FPC Project takes nearly an hour to open. The project file is only 1.8MB. There’s 106 gigs of video files (mts) on an external WD Firewire 800 drive. I used Disk Utility, Tech Tool and Disc Rebellion Pro Maintenance Tools to no avail.
    Model Identifier:          iMac11,2
      Processor Name:          Intel Core i5
      Processor Speed:          3.6 GHz
      Number of Processors:          1
      Total Number of Cores:          2
      L2 Cache (per Core):          256 KB
      L3 Cache:          4 MB
      Memory:          12 GB
      Processor Interconnect Speed:          6.4 GT/s
      Boot ROM Version:          IM112.0057.B00
      SMC Version (system):          1.64f5
    Shane Ross replied 14 years, 8 months ago 4 Members · 14 Replies
  • 14 Replies
  • Shane Ross
    January 9, 2012 at 3:44 am
    [Michael Fasman] “There’s 106 gigs of video files (mts) on an external WD Firewire 800 drive. “
    FCP doesn’t like to work with .MTS files natively. Best to convert them to ProREs.
    Shane
    Little Frog Post
  • Jon Chappell
    January 9, 2012 at 3:46 am
    How long does it take to load when the drive is disconnected and all of the media is offline?
    I’ve seen this before with dodgy media files. These are media files that are not necessarily corrupt but there’s something weird about them that FCP doesn’t like. I once encountered a project that would take ages to load and it eventually turned out that the AE had created a self-contained movie in QT Player from a reference clip and for some reason that was slowing FCP even though QuickTime Player played it just fine. So once the project loads, it may be worthwhile to look through the browser columns to spot clips that don’t quite match the others.
    Also, presumably you have converted the MTS files to ProRes?
    My software:
    Pro Maintenance Tools – Tools to keep Final Cut Studio, Final Cut Pro X, Avid Media Composer and Adobe Premiere Pro running smoothly and fix problems when they arise
    Pro Media Tools – Edit QuickTime chapters and metdata, detect gamma shifts, edit markers, watch renders and more
    More tools…
  • Michael Fasman
    January 9, 2012 at 4:22 am
    After hours of research it appears the issue is the WD GoFlex Free Agent drive which both hangs and isn’t fast enough. I’m now considering either the 2TB CalDigit or G-Raid
    Michael Fasman
  • Michael Fasman
    January 9, 2012 at 4:23 am
    I’m still logging 2 weeks worth of footage, haven’t tried editing. I though FCP 7 automatically transcodes to ProRes? If not do you have suggestions for doing so?
    THANKS!
    Michael Fasman
  • Shane Ross
    January 9, 2012 at 4:56 am
    [Michael Fasman] ” I though FCP 7 automatically transcodes to ProRes? If not do you have suggestions for doing so?”
    No…FCP doesn’t automatically transcode. If you IMPORT, it makes clips that point to the media as is. To convert to ProRes you either log and transfer…using this workflow:
    Tapeless Workflow for FCP 7 Tutorial
    Or use ClipWrap2.
    Shane
    Little Frog Post
  • Rafael Amador
    January 9, 2012 at 5:32 am
    [Michael Fasman] “After hours of research it appears the issue is the WD GoFlex Free Agent drive which both hangs and isn’t fast enough. I’m now considering either the 2TB CalDigit or G-Raid”
    Whatever the media storage you use, FCP won’t be happy with unsupported stuff.
    rafael
    http://www.nagavideo.com
  • Michael Fasman
    January 9, 2012 at 5:05 pm
    Panasonic released the AVCCAM Importer (QuickTime Plug-in component). They say “The AVCCAM Importer QuickTime plug-in component is to enable direct editing of AVCHD “.mts” file (*1) without conversion. AVCHD clips recorded on a Panasonic AVCCAM lineup product can be handled directly in QuickTime 7 and Final Cut Pro 7.0.3.”
    After installing all my clips appear in the bins and they seem to edit fine. Am I missing something? Do I need to spend $50 on ClipWrap?
    https://eww.pass.panasonic.co.jp/pro-av/support/desk/e/download.htm#avccamip
    Michael Fasman
  • Rafael Amador
    January 9, 2012 at 5:19 pm
    [Michael Fasman] “Panasonic released the AVCCAM Importer (QuickTime Plug-in component). They say “The AVCCAM Importer QuickTime plug-in component is to enable direct editing of AVCHD “.mts” file (*1) without conversion. AVCHD clips recorded on a Panasonic AVCCAM lineup product can be handled directly in QuickTime 7 and Final Cut Pro 7.0.3.””
    ou are absolutely right, in fact i downloaded the component (thinking on a Lumix that I’ve just bought), but I completely forgot about.
    I’ve just downloded again. Curiously says “The software was updated for Mac OS X 10.5 (Leopard). (Ver 1.1)’.
    Hope its works on SL.
    rafael
  • Jon Chappell
    January 9, 2012 at 5:32 pm
    FCP is designed to work with QuickTime media encoded with an I-frame codec such as ProRes, Apple Intermediate, Uncompressed, DV, etc. It does not work well with Long GOP media, even if you use a QuickTime importer to rewrap it on-the-fly.
    You are trying to use FCP in a way that it was not designed for and you will run into problems. I would recommend transcoding your media to ProRes or editing the MTS files in an application like Adobe Premiere that is designed to work with native media.
    My software:
    More tools…
  • Shane Ross
    January 9, 2012 at 5:47 pm
    That will let you view the files in QT…and yes, even import them into FCP. But just try to work with those files. It will be a total and utter BEAR to work with.
    Best to transcode.
    If you want the ability to work with AVCHD native, get Adobe PPro CS 5.5. And a GOOD graphics card that enables CUDA and the Mercury Engine. Because you’ll need serious power to manage AVCHD native.
    Shane
    Little Frog Post
