Activity › Forums › Audio › Fostex DC-R302 Stuck in USB mode
  • Fostex DC-R302 Stuck in USB mode
    Posted by Nathan Kendall on June 30, 2016 at 7:49 pm
    I have a Fostex DC-R302: 3 channel recorder that records to SD card and streams to computer via USB. It currently is stuck in USB mode and I cant seam to reset it.
    Eric Toline replied 10 years, 2 months ago 3 Members · 5 Replies
  • Ty Ford
    July 3, 2016 at 1:38 am
    Hello Nathan and welcome to the Cow Audio Forum.
    Power down, disconnect USB cable, take batteries out, hit power button several times, put batteries in, see if it starts without being in USB.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford\’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford\’s Blog
  • Nathan Kendall
    July 17, 2016 at 5:33 am
    I did what you said and the device is still in USB audio ready. Pressing menu does nothing. I thought there was a reset combo of something like pressing and hold exit +menu or exit +record. nothing resets to standard mode.
  • Ty Ford
    July 17, 2016 at 4:41 pm
    OK, reach out to Eric Toline in Florida.
    Have you contacted Foster about it?
    I suspect they have a master reset as you suggest.
    See if he’s run into the problem.
    audioetc@bellsouth.net
    Regards,
    Ty Ford
  • Nathan Kendall
    July 19, 2016 at 12:01 am
    Thanks Ty for that info. I emailed Eric and awaiting response.
  • Eric Toline
    July 19, 2016 at 12:54 am
    Look here for possible help.
    Manuals : Fostex Support
    https://www.fostexinternational.com/docs/tech_support/manuals.shtml
    All Fostex Products. Model, Owners Manual, Supplement, Other. 160, • Owners Manual … DC-R302, • Owners Manual Multi Language, • Quick Start Guide.
    “I push the RECORD button and hope for the best”
