Activity › Forums › Apple Final Cut Pro Legacy › formatting a drive
formatting a drive
Posted by Zeliha Bozkurt on January 17, 2008 at 11:38 amHi
I have a Lacie Drive I would like to format so that it works both on Mac & PC. (FCP & Avid)
Do I format it on a PC or on a MAC?
Any ideas.
Zee.
Ian Francis replied 18 years, 5 months ago 4 Members · 4 Replies -
Jas Sekhon
January 17, 2008 at 2:28 pmU can format it on a mac too just go to applications-utilities
-disk utility.Run the disk utility and u can find ur drive(which u want to format) on the left column select it and choose the erase option from the window and in the volume format option make sure u have selected MS-DOS format (the default is mac os extended) just choose it and press the erase button once erased ur drive is ready to be used both on a mac and pc….
Thanx n regards
JAS -
David Roth weiss
January 17, 2008 at 5:12 pmZee,
The problem with formating the drive for MS-DOS as FAT32 is that it will be slower when used on your Mac and it will have a 4gb file size limitation as well.
You are better off formatting using Apple Extended and installing the application MacDrive on your PC in order to read it.
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
Ian Francis
April 9, 2008 at 11:09 pmI always found picking up the nearest biro and throwing it on the floor whilst shouting works a treat, have you given that a try?
Hope it helps
Ian
