Activity › Forums › Canon DSLR Cameras › Formatted SD card and lost all footage…is there any hope of recovery?
  • Formatted SD card and lost all footage…is there any hope of recovery?
    Posted by Erin Herbst on March 24, 2017 at 2:57 am
    So today while switching out memory cards in my Canon 70D, I formatted a card which deleted all of my footage from that day. Devastated, I immediately looked into if there were any ways of recovering files after formatting a card when IO got home, and found EaseUS Data Recovery software.
    After running a deep search it said it found the 22 clips that I thought I had deleted, so I chucked up the $89 for the full version of the software so I could recover the clips. I ran the recovery and was able to download all the .MOV files, but when I try to open them all I get is a black screen with fuzz audio.
    The audio doesn’t matter to me so much because I recorded that on a separate memory card. But I want this footage back! Is there any hope or are the files damaged a this point?
    This is what the recovered clips look like:
    11175_canoneos70d021.mov.zip
    Warren Eig replied 9 years, 6 months ago 4 Members · 3 Replies
  • Al Bergstein
    March 24, 2017 at 3:03 pm
    I’ve never had any luck when this has happened. Your only hope is to purchase a couple of different programs and try it, but frankly, I don’t think you’ll be successful. The best tool I’ve seen for this Disk Warrior. Losing disk data is the reason I bought cameras with dual SD slots, at greater expense. Very sorry this happened to you.
    Al
  • Ryan Khan
    March 28, 2017 at 5:41 pm
    Have a look at Drill Disk, its pretty easy to use. I always have trouble with deleting thingsI ACTUALLY need. This one really helped me a couple of times. I think it workswith almost everything, like hard/flash drives, memory cards, usually a quickscan is enough for my needs. Has anyone tried it?
  • Warren Eig
    March 29, 2017 at 6:10 pm
    Also check out RecoveRx. Everything is worth a try.
    Warren Eig
    O 310-470-0905
    email: info@babyboompictures.com
    website: https://www.BabyBoomPictures.com
    For Camera Accessories – Monitors and Batteries
    website: https://www.EigRig.com
