Activity › Forums › Apple Final Cut Pro Legacy › Formatted iMac now FCP is running slow….
  • Formatted iMac now FCP is running slow….
    Posted by Jake White on June 8, 2011 at 7:29 pm
    I had to format my Mac a few days ago and wiped everything clean smoothly. Well I loaded FCP back onto my newly formatted Mac along with the Adobe Creative Suite CS5 and now for some reason my Final Cut Pro is not running good anymore.
    I updated FCP to 6.0.6 as well as every other available update for my Mac that came up in the software update window. I am currently running on this:
    MAC OS X 10.5.8
    3.06 GHz Processor
    4 GB Memory
    I set my scratch disk to my 2TB external hard drive so everything would be loaded onto that so I wouldn’t have any problems with speed just as I had it set before I formatted.
    Now I am working with a project I had started before the format and everything is running slow, not just the rendering. When I click a clip from the bin and try to play it from one point it gives me almost a 10 second pause before it actually plays, and when I try to skip ahead it takes longer and even pops up the little spinning wheel from time to time. It never did this before even when I had stuff loaded onto my Mac, now that it is pretty much clean besides the Adobe Creative Suite it seems to be lagging or something. Just to render a 2 second clip it takes a couple minutes which it never even came close to before.
    I’m working with video that is not HD and the format is all .MOV but again that shouldn’t be the problem because EVERYTHING worked perfect before I formatted my Mac, great speed and everything. I am kind of at a loss, I keep changing things here and there hoping it will work but to no avail, any thoughts guys? I tried to list all of the info/specs that you may need to know.
    Eric Hansen replied 15 years, 3 months ago 4 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    June 8, 2011 at 9:01 pm
    How did you load FCP back onto the computer? via the install disks?
    Shane
  • Jake White
    June 9, 2011 at 12:08 am
    Yes I installed it with the installation discs.
  • Alexander Kallas
    June 9, 2011 at 9:13 am
    Clean up your directories with DiskWarrior.
    Cheers
    Alexander
  • Jake White
    June 9, 2011 at 6:00 pm
    Would I need to do that if I just formatted though? There is hardly anything on my Mac right now.
  • Jake White
    June 10, 2011 at 7:10 am
    Still looking for some assistance on this, after working with it for a while it seems to be getting worse. I am at a loss here haha.
  • Alexander Kallas
    June 10, 2011 at 12:48 pm
    Even just installing software can scramble your directories, so definitely do it now, and every time your Mac slows down.
    Cheers
    Alexander
  • Alexander Kallas
    June 10, 2011 at 10:39 pm
    Did you try DiskWarrior?
    Cheers
    Alexander
  • Eric Hansen
    June 13, 2011 at 4:18 pm
    make sure that “Put the Hard Disks to Sleep When Possible” is UNCHECKED in System Preferences > Energy Saver
    e
    Eric Hansen – https://www.erichansen.tv
