Activity › Forums › Panasonic Cameras › format SD and P2 cards
Posted by D_easton on August 5, 2007 at 1:20 pmJust got a HVX200 says it is compatible with the new 16GB cards – We can’t format an SD card or see a 16GB P2 – is there some master camera write protect setting? Help!
ThanksD_Easton
John Fishback replied 19 years, 1 month ago 3 Members · 4 Replies -
Ron Thompson
August 5, 2007 at 2:24 pmDid you update your camera? HVX200 is compatible after a firmware update…
https://www.panasonic.com/business/provideo/support/software_16gbp2.asp -
D_easton
August 5, 2007 at 3:54 pmThe camera has version 4.6 and should see the 16GB cards – problem is I have 3 different SD cards and the camera will not allow me to format any of them. If I could format an SD card I guess I could copy the firmware to it and try updating again. Any clue on why the camera won’t see an SD card? Thanks
D_Easton
Ron Thompson
August 5, 2007 at 4:49 pmMaybe someone more advanced can answer…MY guess would be to format the SD card from a computer (Mac, Windows) then try and load it in the camera and see if that works.
John Fishback
August 6, 2007 at 1:19 amI believe you have to format it in the camera. How big a card are you using. I think you only need a 64MB card. A card over 2GB might not work.
John
Dual 2.5 G5 4 gigs RAM OS 10.4.8 QT7.1.3
Dual Cinema 23 Radeon 9800
FCP Studio 5 (FCP5.1.2, DVDSP4.1.1, Comp2.3, STP1.1, Motion 2.1.2)
Huge U-320R 1TB Raid 3 firmware ENG15.BIN
ATTO UL4D driver 3.50
AJA IO driver 2.1 firmware v23-28
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neuman U87s, Genelec Monitors, PrimaLT ISDN
