Activity › Forums › Blackmagic Design › Format Hyperdeck Shuttle 2 to record Dnx files
  • Juan Salvo
    July 16, 2012 at 4:39 pm
    Connect it to a computer using usb and run hyperdeck utility.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Andreas Wojtaschek
    July 16, 2012 at 4:41 pm
    Download the Hyperdeck Utility from the BMD Homepage. Install it on a PC or Mac. Connect the Hyperdeck via USB2 and start the utility. Then you can change to DNxHD, ProRes or Uncompressed. And you can change some Timecode settings of your Hyperdeck.
    EDIT:
    OOps – Juan was fatsre 😉
    Regards
    Andreas
    Entertainment Producer IHK
    mindandvision
  • Joshua Helling
    July 16, 2012 at 11:10 pm
    Just a smaller correction. There is no ProRes setting on the Hyperdeck Shuttle 2.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
    July 17, 2012 at 9:07 am
    Yes Joshua,
    thanks for the correction. I thought he was refering to Hyperdeck Studio. The Shuttle 2 has no ProRes that is correct.
    Cheers
    Andreas
    mindandvision
  • Afsheen Aziz
    July 17, 2012 at 7:23 pm
    its good 😉
