forgot to shoot 24pa (just p) Can’t inverse telecine in cinema tools or jes deinterlacer
The DP on this project forgot to shoot 24pa and only shot 24p (ok, I admit it, I was the DP) and now in the editing I am having a very hard time getting it into a 24p timeline.
First of all, when I select a clip and chose inverse telecine in final cut, it tells me that “none of the clips selected are 29.97 bla bla,,” when it is, otherwise I wouldn’t be having this problem!
I can open cinema tools by itself and choose a clip from finder, it will get half way through the process and then tell me it has failed.
So then I tried JES deinterlacer, and when ever I add on of the clips, it greys out the inverse telecine options.
*The codec is the rewrapped dvcpro 1080 from a HPX170 P2 system. I am using the rewrapped .mov files, not the original mxf files for all of this*
Please HELP!
Nils Hoover
https://nils.tv
