Activity › Forums › Apple Final Cut Pro Legacy › Force Render and Automatic Pitch Correction.
Posted by Jerry Wise on October 25, 2010 at 8:18 pmare there keystrokes to Force Render the entire timeline?
and…on my old Smoke editing system i could do a fit to fill with audio and it would automatically correct the pitch…any luck doing this in FCP?Mike Krause replied 15 years, 11 months ago 3 Members · 4 Replies -
Shane Ross
October 25, 2010 at 8:33 pm[jerry wise] “are there keystrokes to Force Render the entire timeline?”
OPT-R.
[jerry wise] “on my old Smoke editing system i could do a fit to fill with audio and it would automatically correct the pitch…any luck doing this in FCP?”
Nope…no pitch shift in FCP…sorry. Have to fix that in audio editing apps like ProTools or Logic or Soundtrack pro. Yeah…bummer. I miss that from my Avid too.
Shane
Read my blog, Little Frog in High Def -
Mike Krause
October 26, 2010 at 5:42 amUm… Audio Filters -> Apple -> AUPitch. It’s not “automatic” (you gotta’ add it manually) but it does the job just fine.
Jerry Wise
October 28, 2010 at 10:52 pmsorry…that takes too long. dont have time to fiddle with pitch. gotta get it done and move on. thats how i’m doing it now but i need a faster way. outta luck i guess. there’s gotta be an easy plug-in.
where’s my old Smoke.??? -
Mike Krause
October 29, 2010 at 10:17 pmYou could build a series of pre-pitch-corrected audio effects and just drop them on your fit-to-filled clips. Takes a bit of time ahead of time, but could make your life easier. At one facility I work for regularly I’ve set up something along these lines and use it every time I’m there.
Check out the “speed chart” – https://dl.dropbox.com/u/1686339/speed_chart.pdf – Isazaly Mohd Isa was kind enough to post on a related thread (https://forums.creativecow.net/thread/8/1062027#1062172) and see if it works for you.
For a number of things I’d rather be working on a smoke, too, but all budgets (including my own) have limitations.
