Activity Forums Adobe Premiere Pro Force relink Premiere?
  • Force relink Premiere?
    Posted by Thomas Morter-laing on May 27, 2016 at 3:50 pm
    Hiya,
    So Im trying to offline a bunch of MXFs so I can relink to the movs I converted through media encoder. I dont have time to reconvert them. When I try and relink some of the clips it gives me the ‘The selected file cannot be linked because it has 2 audio channels and the clip was created with 4 audio channels with a different type’.
    The thing is, I dont care about the audio, it’s not important. Ive already buit a sequence with the MXFs but the computer is going to melt soon unless I can relink to something it handles a bit better. Is there no way to force relink ‘on batch’?
    Thanks in advance D:
    sarthak choukse replied 1 year, 10 months ago 8 Members · 7 Replies
  • 7 Replies
  • Alex Udell
    May 27, 2016 at 6:31 pm
    Hi…
    Can you select the MXF’s in the Project Panel prior…and do modify audio…and set the settings to be identical to your proxies?
    then maybe it will let you relink?
    dunno….worth a shot…
    (maybe test this in a duplicate of your project so you don’t do any damage to work you may have already done)…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    Let’s Connect on Linkedin
    Examples: Retail Automotive Motion Graphics Spots
    Example: Customer Facing Explainer Video
    Example: Infotainment & Package editorial
  • Michael Klaumann
    June 7, 2017 at 5:08 pm
    Did you find a solution to this? I’m having the same issue right now. Trying to AAF an Avid Cut to PP and giving me the same error. Seems silly that you can’t just bypass this as PP found the video and audio that was used in the original cut. It just creates a huge amount of wasted time to get those few clips into PP.
  • Julius Miller
    June 12, 2017 at 9:42 am
    I found another post that said you need to select each file in the project panel and right click and set its audio option to ‘Use File’.
    I did this but the clips still won’t link.
    I am just trying to link some proxies I made – not the real files
  • Ofentse Mwase
    July 16, 2017 at 1:43 am
    I found a solution! Go into working linked timeline, Select all clips, right click, Modify Audio, Number of Audio clips 4, tick left right like the default audio, save project and relink again ☺
  • Misha Mazor
    March 26, 2021 at 2:48 pm
    Good idea, but crashes when I try that
  • Sam Sapin
    October 24, 2024 at 1:14 pm
    Uncheck the ‘File extension’ option in the relink window. A DIT just told me this and it works.
  • sarthak choukse
    October 30, 2024 at 2:08 pm
    Unfortunately, Premiere Pro can be picky about audio channels when relinking. One workaround is to create a new sequence with the MOVs and then copy your edits from the MXF sequence over. If you really want to batch relink, you might try using a script or plugin that can force the relink without worrying about audio channels.
