Activity › Forums › Apple Final Cut Pro › Force optimized transcode
  • Force optimized transcode
    Posted by Oliver Peters on May 23, 2012 at 3:41 pm
    Is there a way to force a transcode on import of camera files? I have C300 files (50Mbps XF). I want these to be transcoded to ProRes on import, but FCP X sees this as an optimized format, so the option is greyed out. Therefore, no transcode and the copies are the same codec. Any way to change this?
    Also the imported files default to being named with the UID instead of the camera name. It can be renamed to the original camera name in the Event Browser, but the media files have the UID. Any way to change this default behavior, since the UID name is meaningless to other users down the line working with other applications.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Oliver Peters replied 14 years, 4 months ago 2 Members · 2 Replies
  • David Battistella
    May 23, 2012 at 7:15 pm
    I don’t think you can change this.
    Perhaps the best way to accomplish this is with compressor. Maybe that is where you could change the usd name as well.
    David
    ______________________________
    The shortest answer is doing.
    Lord Herbert
    https://www.davidbattistella.com
  • Oliver Peters
    May 23, 2012 at 7:38 pm
    [David Battistella] “Perhaps the best way to accomplish this is with compressor. Maybe that is where you could change the usd name as well.”
    This works fine with FCP 7 L&T, so I’ll probably just use that for conversion/ingest and then cut in X.
    Oliver
    Orlando, FL
