Activity Forums Media 100 Force M100 to strip Alpha on import?
  • Force M100 to strip Alpha on import?
    Posted by Jaeson Koszarsky on July 13, 2011 at 6:20 pm
    Occasionally I import an MOV file that M100 says has an alpha channel, and M100 wants to change the codec to M100 HD. I don’t need the alpha and would rather not switch to the HD codec. Is there a way to force Media100 to stick to the original codec and just ignore or strip the alpha channel? Thanks.
    Jaeson
    Dave Mccarthy replied 15 years, 1 month ago 3 Members · 4 Replies
  • Floh Peters
    July 14, 2011 at 9:58 am
    No, currently not.
  • Dave Mccarthy
    July 14, 2011 at 5:05 pm
    You can use ProRes444 as an alternate codec that supports alpha.
  • Jaeson Koszarsky
    July 14, 2011 at 8:15 pm
    Media100 doesn’t give the option to select an alternative codec when importing. I can reprocess the file before the import with another app or inside the M100 after the import, it’s just a few extra steps.
  • Dave Mccarthy
    July 14, 2011 at 8:26 pm
    True, but if you select ProRes444 before the import, that choice will be honored. It’s only because you have a non-alpha codec selected that we force the change.
