Activity › Forums › Apple Final Cut Pro Legacy › Force abort capture in FCP without saving clip?
  • Philip Johns
    April 2, 2008 at 1:35 pm
    Doesn’t ESC work? If not you can delete them pretty simply – right click the digitized clip and click “Make offline” where you can delete the file from your disk, then push delete with the clip selected and it’ll go. Hope this helps.
    Philip Johns
