Activity Forums Adobe After Effects Expressions force a var to stop updating every frame
  • force a var to stop updating every frame
    Posted by Christian Labuska on April 29, 2010 at 3:11 pm
    hi there,
    is there a way to store the current time in a variable, when a specific event happens. or in other words: can i force a var to stop updating every frame?
    in detail:
    i have a keyframed slider control (1900 … 2000)
    i have a bunch of layer which names goes like that: 1902_…/1904_../…
    with the following expression i set the opacity:
    n = thisLayer.name;
    a = n.split(“_”);
    e = a[0];
    if(e<=thisComp.layer("SLIDER").effect("SLIDER")("Slider Control")) 100; else 0;
    so far so good.
    now i want that, if the layer’s opacity jumps to 100, the layer scales from 0 to 100 which would look like this:
    ease(time, timeAtEvent, timeAtEvent+20, 0, 100)
    tried to store the time in a variable in different ways (if else/while,…) but couldn’t get the variable to stop updating when the event shown above happens.
    somebody got an idea?
    thanks a lot
    Christian Labuska replied 16 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 29, 2010 at 8:09 pm
    Variables don’t survive from one frame to the next, so your scale expression needs to figure out how long it’s been since the event. It will look something like this:
    if (transform.opacity >= 100){
    eventTime = time – thisComp.frameDuration;
    while (transform.opacity.valueAtTime(eventTime) >= 100) eventTime -= thisComp.frameDuration;
    t = time – eventTime;
    // calculate scale here based on t
    }else{
    value
    This expression assumes that opacity starts out at less than 100%. If you have it set so that it’s always 100%, the expression will time out looking for the transition, so don’t apply the expression until you’ve keyframed the opacity (or modify the expression to check for that condition).
    Dan
  • Christian Labuska
    May 3, 2010 at 12:36 pm
    Thanks a lot Dan.
