Activity Forums Panasonic Cameras For Shane Ross
  • For Shane Ross
    Posted by Anthony Carnaxide on November 21, 2007 at 9:59 am
    Hi Shane,
    I hope you can help. I’m using FCP2 on a Macbook Pro 6.0.2 and Quick time 7.3
    I imported P2 footage using the Log and Transfer in FCP2. firewire Lacie 800 ext drive hooked up Capture Scratch was set to that drive, I made a new seq. and new folders and saved the project as XYZ. Set each folder the logging bin as needed.
    The footage went to the folders with no problem. Played back footage from the folders and everything was there. We then save the project closed FCP Open the Lacie drive open the Seq and everything was there.
    When I returned home 2 folders were off-line I have done this many times without any problem. This happened on 2 different Lacie drives. I don’t think it is a drive problem. Is there a problem with QT 7.3 or FCP2 6.0.2 when doing Log and Transfer?
    Anthony Carnaxide replied 18 years, 9 months ago 4 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    November 21, 2007 at 11:42 am
    [Anthony C] “Is there a problem with QT 7.3 or FCP2 6.0.2 when doing Log and Transfer?”
    Yes….it’s broken. I got it to work once, but not again. FCP 6.0.2 has messed up a basic function of FCP.
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
  • Anthony Carnaxide
    November 21, 2007 at 12:13 pm
    Are you using Raylight to make tranfer to FCP?
  • Shane Ross
    November 21, 2007 at 12:16 pm
    Raylight doesn’t TRANSFER anything…you misunderstand what it does. It allows you to access the MXF files WITHOUT transferring anything. Launch Raylight, have it scan your machine for P2 MXF files, and then FCP can edit those natively. No converting to QT.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Anthony Carnaxide
    November 21, 2007 at 12:29 pm
    Thanks.
    Will there still be a issue of the Media going off line in FCP2?
  • Peter Sassi
    November 21, 2007 at 1:51 pm
    I just got an email from Apple support and it seems that only those with the disappearing P2 problem at some point had P2 Log installed. Removing it doesn’t seem to fix even with a reinstall of FCP 6.0.2
    Curious, how many that are experiencing the problem had/have P2 Log installed?
    Peter Sassi
  • Anthony Carnaxide
    November 21, 2007 at 2:05 pm
    Peter.
    I do not have P2 Log installed. What a mess on Apple part. Never had a problem with the old Log and Capture P2 or with Log and Transfer with 6.0
  • Noah Kadner
    November 23, 2007 at 7:43 pm
    Anthony-
    Do you have any other P2 helpers installed- like HD Log, P2 CMS, Raylight? Ever run a demo of any of them?
    -Noah
    Unlock the secrets of the DVX100, Apple Color and now the HVX200!
    https://www.callboxlive.com
  • Anthony Carnaxide
    November 24, 2007 at 1:38 am
    None
