Activity › Forums › AJA Video Systems › FOR PAL READERS : FCP 5 Uncompressed 10-bit + 8-bit sequence presets
Posted by Ben Cheng on July 15, 2005 at 12:10 pmHi readers in the PAL world,
A quick note about the FCP 5.0.2 Uncompressed 10-bit + 8-bit PAL sequence presets
I noticed both presets had the field domainance set to Lower instead of Upper
Please change it
Cheers
BenBerenger Capmany replied 21 years, 1 month ago 6 Members · 7 Replies -
Walter Biscardi
July 15, 2005 at 12:24 pmReport that directly to Apple. It has nothing to do with AJA.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Christopher Tay
July 15, 2005 at 4:45 pmWally,
Yes it has nothing to do with AJA but it does affect AJA PAL users. Ben is just letting PAL users know about what he has discovered in case they run into the same issue as he had. This affects other card flavours as well since it is in the Apple PAL Uncompressed presets but because he was doing an install with the IoLD, he feels it would be good info to spread in the AJA forum.
-chrispy
Walter Biscardi
July 15, 2005 at 5:50 pm[chrispy] “Ben is just letting PAL users know about what he has discovered in case they run into the same issue as he had”
That I understand, I just want to make sure he sends this back as feedback directly to Apple so they can address this. This is the same type of thing that happened in Motion 1.0 where some NTSC presets were upper field first.
Christopher Tay
July 16, 2005 at 4:03 pmWhy can’t we all just go progressive…and lose this whole field thing. Better still, progressive with a single frame rate for everyone. Let’s just live in a 24p world.
-chrispy
J Paulson
July 16, 2005 at 9:17 pmI have had the same exact issues… Uncompressed 10-bit is a pain in the rear.
Marco Solorio
July 17, 2005 at 9:08 am[chrispy] “Why can’t we all just go progressive…and lose this whole field thing. Better still, progressive with a single frame rate for everyone. Let’s just live in a 24p world.”
I’d die and gone to heaven if that ever came true!!!
Marco Solorio | OneRiver Media
Berenger Capmany
August 24, 2005 at 10:54 pmYES!
I support this!
as a rule.. all codecs are upper except DVPAL which is lower..
Greetinngs from the Mediterranean Sea!
