Activity Forums Zaxwerks for Matt Rhodes…
  • for Matt Rhodes…
    Posted by Jay Thompson on December 8, 2007 at 8:22 pm
    Hi Matt,
    I know your the technical guy at Zax’s palce–and you have helped me before. I building an animation that I think has an error that I tryingto fix. But I can’t find out whats causing it.
    I have two tracks, one is static and one rotates. The only way I found to get it rotate correctly is the way I’ve programed it.
    Here it is.
    At about 2 sec and 18 frames the rotating element FLIPS and then after a frame or two goes back and finishes correctly.
    It’s like it rubber bands incorrectly and fixes itself. I’d really like to use Pro Animator for this project—BUT I CAN’T if this is going to happen. Can you take a look and advise me.
    -jay
    Matt Rhodes replied 18 years, 9 months ago 2 Members · 3 Replies
  • Jay Thompson
    December 8, 2007 at 11:09 pm
    Another question Matt. Is there a way to alter the anchor point of a grouped set of objects? I can do this in After Effects—but I’m not sure about Pro Animator.
    -jay
  • Matt Rhodes
    December 11, 2007 at 5:27 pm
    Hi Jay.
    We currently don’t allow you to modify the anchor point of groups.
    I’m looking at your project now.
    Matt Rhodes
    Zaxwerks, Inc.
  • Matt Rhodes
    December 11, 2007 at 5:49 pm
    Hi Jay.
    You’re seeing the results of gimbal flip,
    which happens when you animate from -180 degrees
    to 170 degrees. The two angles look very similar,
    but transitioning from one to another is causing the flip.
    A workaround is to not have a transition, but to rather
    just put a single frame Pose that sets the Z rotation to
    175 degrees for each of your objects. This simulates
    the transition you’re looking for.
    There are other ways to get your animation to work,
    rather than the frame-by-frame approach you’ve taken.
    If you could send me your original .ai file, I can quickly
    mock up a scene that will rotate your objects in a
    circle. You can learn from that.
    Send files to: matt@zaxwerks.com
    Matt Rhodes
    Zaxwerks, Inc.
