Activity Forums Adobe After Effects Expressions For loop to count layers not behaving as it should
  • For loop to count layers not behaving as it should
    Posted by Doc Byrne on March 19, 2024 at 11:03 am
    Hi folks,
    I’m working on a project and I need to count the number of layers with a specific name and display it as a number on screen. I’ve been using a for loop but unfortunately, I can’t quite get it right and I have the feeling I’m missing a condition in the code but I can’t figure out what it is.
    When I apply the following code to a text layer, it displays the correct number when I add or delete a layer called Depth provided it happens below the text layer. But if I add or delete layers above the text layer, the number increases or decreases the number, regardless of what the layer is called.
    I know it’s probably something obvious but I’m stumped. Can anyone help please?
    var result = 0;
    for (var i = 1; i <= thisComp.numLayers; i++) {
    var compLayer = thisComp.layer(i);
    var layerName = compLayer.name;
    if (layerName == "Depth") {
    result+=i;
    break;
    result;
    Brie Clayton replied 2 years, 6 months ago 3 Members · 3 Replies
  • Julian Chojnacki
    March 19, 2024 at 1:27 pm
    Hi! You’re almost there, but instead of adding the layer index i to result, you should add 1 each time you find a layer named “Depth”. Also, remove the break statement to ensure the loop continues to check all layers even if your condition is met.
  • Doc Byrne
    March 20, 2024 at 1:17 pm
    That’s brilliant! Thanks a million for this, Julian. Can’t believe I got an i and a 1 confused 🤦‍♂️
    It’s running perfectly now.
  • Brie Clayton
    March 20, 2024 at 2:19 pm
    Thanks for solving this, Julian!
