Activity Forums Adobe After Effects Expressions For Loop Statement combined with Hover-Over Effect
  • For Loop Statement combined with Hover-Over Effect
    Posted by Mateo Baldasare on April 21, 2023 at 1:40 pm
    Hi there!
    I’m trying to make a hover-over effect activated by different shape layers. So each time one of the moving circles gets closer to the static circle layer, its size changes.
    I managed to change the size but it only works with one shape layer, then the rest are ignored. I’ve attached a video for reference.
    This is the expression that I used:
    l = 0;
    for( i=1; i <= thisComp.numLayers; i++){
    curLayer = thisComp.layer(i);
    if(curLayer.name.slice(0, 3) == “C_M” && curLayer.effect(“Circle Moving”)(“Fill Color”) == 1) {
    pointA = curLayer.toComp(position)[1];
    pointB = thisLayer.toComp(position)[1];
    l = length(pointA, pointB);
    s = ease(l,0,200,53,33);
    [s,s]
    What am I missing? Or is there a better way to achieve the same result?
    Mateo
    Brie Clayton replied 3 years, 4 months ago 3 Members · 3 Replies
  • Dan Ebberts
    April 21, 2023 at 3:46 pm
    I haven’t tested this, but I think, as you loop through the layers, you need to save off the shortest distance, and use that at the end, like this:
    l = 0;
    lMin = 999999;
    if(curLayer.name.slice(0, 3) == "C_M" && curLayer.effect("Circle Moving")("Fill Color") == 1) {
    lMin = Math.min(l,lMin);
    s = ease(lMin,0,200,53,33);
    [s,s]
  • Mateo Baldasare
    April 25, 2023 at 4:32 am
    Thanks so much for this, Dan! it works great 😃
  • Brie Clayton
    April 25, 2023 at 3:06 pm
    Thank you again, Dan!
