Activity › Forums › Apple Final Cut Pro Legacy › for delivery on the web
  • for delivery on the web
    Posted by Gabriela Enis on June 10, 2009 at 1:44 pm
    I’m working on a DV Pal project on FCP5. I have received these specs:
    “For delivery on the web, we require an MPEG-2 program stream file consisting
    of muxed (multiplexed) MPEG-2 Video and MP2 Audio in a .mpeg file container.
    MPEG-2 Video should be DVD quality or higher. High Definition (720 or 1080)
    resolution is welcomed when available.
    MP2 Audio should be 160 kb/s or higher.”
    Can I deliver by just sending a DVD made on iDVD or do I need to work differently?
    Thank you for any help.
    Gabriela
    Michael Sacci replied 17 years, 3 months ago 4 Members · 5 Replies
  • Rafael Amador
    June 10, 2009 at 2:16 pm
    Hi Gabriella,
    The specs they give you do not match a standard DVD.
    you have to decode if you upscale to 720/1080 or not.
    If so, I would recommend you to do it in two steps.
    First enlarge the picture and de-interlace.
    Then make the MPEG-2.
    You can do the MPEG-2 with the MP2 Audio in Compressor.
    The Audio it have a ix data-rate that, if I’m not wrong, is 240Kbps.
    That used to be the standard.
    In the Encoder> Extras, select “Multiplexed Audio..” and the kind of stream.
    Rafael
    http://www.nagavideo.com
  • Gabriela Enis
    June 10, 2009 at 4:39 pm
    Rafael,
    Thank you for the answer. I’ve got some questions
    “First enlarge the picture and de-interlace”. How do I do this in FCP5?
    “Then make the MPEG-2.
    You can do the MPEG-2 with the MP2 Audio in Compressor.”
    I have Compressor 2 and I only have DVD PCM audio settings.
    this is the first time I’m usign Compressor so I’m a bit lost.
    Any help will be appreciated.
    gabriela
  • Joey Burnham
    June 10, 2009 at 5:59 pm
    Compressor has a MPEG-2 Program Stream preset that you should check out.
    Joey
  • Rafael Amador
    June 10, 2009 at 6:20 pm
    [Gabriela Enis] “”First enlarge the picture and de-interlace”. How do I do this in FCP5? “
    This you better do it with Compressor.
    Chose You need to duplicate and modify a QT Preset. Set it 1280×720. Square Pixels. Field Order: Prgressive. the same time-base than your DV sequence ( you haven’t mention if PAL or NTSC).
    Choose a good codec. You have no ProRess so if you can use 10b Uncompress or 8b Uncompress. If not PhotoJPEG 90%. Don’t use DV.
    In Compressor you need to set the “Frame Control: ON”.
    Resize Filter: Beter.
    Output Fiels: Progressive.
    Deinterlace: Better.
    The process will take time but you can get a really good picture. FC can not.
    Once you have your QT 720p, you import it again to compressor and you use a High Quality Double Pass MPEG-2 preset.
    You need to rise the data-rate. I’m working now with Compressor 3 and i don’t remember the Presets.
    You need to look for the option ” Multiplexed MPEG-1/Layer2 Audio”. Is in somewhere ther.
    rafael
  • Michael Sacci
    June 11, 2009 at 1:03 am
    The first post said they accept HD “when available” doesn’t seem to me that they are asking for footage to be up-rez’d.
