Activity Forums Apple Final Cut Pro Legacy Footage wont play down…
  • Footage wont play down…
    Posted by Darren Peister on January 22, 2010 at 2:19 am
    I was using FCP v6 and everything was honkey-dorey. The project Im now working on was started in another facility running v7 so I had to bump mine up. I upgraded to v7 and when I went back to the edit in my system the footage in client monitor didnt come up. So I went to “AV Settings – AV Devices and went to View-External Video- All frames- refresh. The image in my canvas now comes up on the client monitor. But the timeline wont play video down; I get a freeze frame. It wont play in the Canvas either. I can hear the footage if I play itand when I stop the canvas/client monitor update. But no motion. This worked at the other facility. What gives? Thanks
    Geek/Nerd
    Mac Pro 2.26 GHz Quad-Core Intel Xeon
    16 GB RAM, 3Gig internal Raid
    Darren Peister replied 16 years, 8 months ago 2 Members · 3 Replies
  • Shane Ross
    January 22, 2010 at 4:20 am
    What is the format of the footage? How are you connected to the client monitor?
    Shane
  • Darren Peister
    January 23, 2010 at 7:58 pm
    The footage is DVCProHD100 and it was captured in another system. I copied that footage from the client’s drive to my 1TB drive and connected it to my CPU via a SATA cable. The client monitor on my system comes from the CPU’s 2nd monitor output (that tiny apple-proprietary port) and an adapter to HDMI then connects it via HDMI to the monitor. Understand that this setup was working fine before I intalled v7 of the software. I have a raid-0 set of drives in the CPU; (3) 1TB drives striped as one. As a test I pulled a file from that internal raid that I used in my last project into my current project and it will not play either. I can only hear it and the monitors update once I pause on a shot. That shot wouldnt even frame up correctly in the viewer. It was stretched too far left to right. What is going on????
    Geek/Nerd
  • Darren Peister
    January 23, 2010 at 8:44 pm
    After a moment of desperation, I shut off the client monitor (View, Video Playback: none) and the video plays down in FCP! So the question then is: Why wont it play back in the client monitor? Hmmmm. Stumped.
    Geek/Nerd
