Activity Forums Apple Final Cut Pro Legacy footage switches between 16:9 and 4:3
  • footage switches between 16:9 and 4:3
    Posted by Jhbrewer on December 20, 2006 at 9:34 pm
    I’m working on a project, and I exported the final video from FCP via Compressor in .m2v and two audio files (maybe .aiff and .ac3). The file is widescreen, I can pull it up in QT and it plays in 16:9. I imported it to iDVD and played the preview, and it is in 4:3 with grey bars on the sides. The project is set to widescreen, and all of the menus are widescreen.
    Any ideas?
    Jerry Hofmann replied 19 years, 9 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    December 20, 2006 at 10:06 pm
    iDVD can’t accept MPEG files from Compressor. You need to export it as a reference movie that uses “current settings”…. file/export/QT movie… Import that file into iDVD for the encode and burn.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
