Activity › Forums › Adobe After Effects › Footage stays still
  • Footage stays still
    Posted by Mariano Garcia on July 10, 2012 at 9:52 pm
    Hi, I hope someone can help me with this issue. I’m using some footage from videocopilot.com and the first time everything worked fine but when I opened the project again(just some minutes after) the footage didn’t play anymore, it just stays still in the a single frame (the last one), some of the clips plays but just when the preview resolution is at quarter. The footage is originally 29.97 FPC conformed as 24 in AE. It is in a 24 composition. What can be happening?
    I’m using AE CS3 in a Leopard Mac 2GB Ram, 2.4 GHZ Intel 2 Core.
    Thank you.
    Mariano Garcia replied 14 years, 2 months ago 2 Members · 3 Replies
  • Tudor “ted” jelescu
    July 12, 2012 at 10:09 pm
    What is the resolution of your project/footage?
    It may be that the 2GB of RAM you have are not enough if you try a full frame preview and you may need to purge the cache or restart AE and then work at half or even a third resolution/preview size.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Mariano Garcia
    July 14, 2012 at 7:21 pm
    Hey thank you so much. About purging the Cache, how to do it? just clean database and cache button?
    Anyway I was really hoping it was a RAM issue, but I’m not that sure anymore, I enabled disk cache. Pre conformed the footage, and the problem stills happening (sometimes it doesn’t even plays in quarter) even thought this footage is way smaller and less heavy than the rest of the footage that plays smoothly.
    By the way, the problematic footage was originally in H.264 I exported it as Apple pro res to match the rest of the project. So, any other idea? thanks.
  • Mariano Garcia
    July 14, 2012 at 7:43 pm
    Nevermind looks like it just needed to restart the program after the changes, everything works fine now. Thnak you for everything.
