Activity Forums Adobe After Effects footage size/aspect
  • footage size/aspect
    Posted by Derek Fromby on January 2, 2010 at 4:23 pm
    I use vegas platinum 9.0 to edit my video footage. Here’s my problem… when I import my footage into adobe after effects cs4 and render it, once Im done with the effects part. When I import it back into vegas the height is fine but the width has become a little smaller. This is a problem because I have a lot of clips thats has effects. And trying to resize every clip once I bring it back in is a very long process. How can I fix this problem so that my imported footage stays the same size as the video it came from and what do I do?
    Tricky
    Brian Fisher replied 16 years, 8 months ago 2 Members · 1 Reply
  • Brian Fisher
    January 2, 2010 at 10:37 pm
    Try checking your pixel aspect ratio under the AE composition settings. Your source material and AE comp should have the same ratio. Try changing it from what it is now (maybe from square pixel to 1.09) and see if that helps.
    Mac Pro, 10.5.8, 2×2.66GHz, 6GB RAM, GeForce 8800GT 512MB
