Activity Forums Adobe Premiere Pro Footage settings are different outside Premiere
  • Footage settings are different outside Premiere
    Posted by Josh Comer on April 28, 2011 at 6:01 pm
    I’m using Premiere CS5 to do some video editing and have had a lot of trouble with importing footage into appropriate sequences. Many times I have to edit videos that I do not have the original footage for (for example, I am given an .mp4 or .mov of a movie instead of footage itself). TOday I ran into an issue because I was trying to import a .mp4 into premiere. I threw the video into MPEG Streamclip and looked at the stream info to try to figure out the specifics of the video (since I do not have original footage, I am not always given this information). I used that to set up my sequence presets. MPEG Streamclip said that it was 640x 480 (1.0 square pixels) 29.94 FPS. And the audio was 44100 KHZ. So, i create the sequence with the “desktop” setting. However, when I bring in the footage, it is not the same as it was in MPEG! In premiere its at 59.97 frames per second, and the audio and video syncing is off. It also leaves out part of the audio (so i cant even manually sync it). the video plays fine outside of premiere and when I convert it to .mov it works like gypsy magic. Is there something I’m doing wrong in working with .mp4 in premiere? Is there a better way to set up a sequence to match footage?
    Josh Comer replied 15 years, 4 months ago 2 Members · 2 Replies
  • Jeff Greenberg
    April 29, 2011 at 11:00 am
    Try Media Info
    Second, try right clicking on the clip and choose New sequence from clip in Premiere Pro (don’t know if that’s in 5.0. If not, drag the footage to the “new” icon in the Project Panel.)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Josh Comer
    May 5, 2011 at 3:47 pm
    Thanks! Media Info looks like a great tool. And I didn’t know that you could form a sequence on the clip. However, I’m still having issues. The video settings in media info do not match premiere, and if i try to interpret the footage in premiere to fix that, the footage just gets distorted. The audio and video will play perfectly fine in MPEG Streamclip or Quicktime, but once imported into Premiere, the audio and video are out of sync. So, now, even if I create a new sequence or interpret the footage, the audio and video are too distorted to do anything. If I create a new sequence to match, the audio is normally spoken (although its cut short) and the video is choppy and out of sync. If I interpret the footage to what it should be, the video plays perfectly, but the audio is slowed down (and dropped pitches with it). So, should I just abandon .mp4 in premiere? or is there something to do for this?
