Activity Forums Apple Final Cut Pro Legacy Footage not syncing when rendered
  • Footage not syncing when rendered
    Posted by Brian Tetamore on September 15, 2009 at 6:21 pm
    There’s probably a better way to explain this, but here goes. I have DV footage in a viewer – set an in and out – edit into a sequence. Everything is fine. Then I render that section (it’s being inserted into an HD timeline, yes painful).
    BUT, after rendering the clip the footage changes to a different point in the original video segment that I lifted the clip from. For instance, I pull a 2 second clip from 50 seconds in and after rendering the clip now references a different portion of the video from 23 seconds. Weirdest thing I’ve ever encountered.
    Same thing happens with a still image. I create a still image of a frame in the original video and once rendered or even exported, the resulting still frame is from a different point in the original video.
    Any thoughts?
    The Visual Rabbi
    TheVisualChurch.com
    “Crafting Visual Messages to Engage and Persuade”
    Brian Tetamore replied 17 years ago 2 Members · 2 Replies
  • David Roth weiss
    September 15, 2009 at 6:25 pm
    Sounds as if your prefs need trashing immediately… So, don’t pass go, don’t collect $200, but do trash your prefs.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Brian Tetamore
    September 15, 2009 at 9:32 pm
    Thanks David. I needed that “Get out of Jail Free” card.
    Seemed to do the trick. That was bizarre. After all these years, I still encounter new things. Oh, the joys of editing.
    God’s best,
    Brian
    The Visual Rabbi
    TheVisualChurch.com
