Activity › Forums › Apple Final Cut Pro Legacy › Footage not showing up with right fps
  • Footage not showing up with right fps
    Posted by Scott Barnes on September 7, 2006 at 3:09 am
    I have an interesting problem that i have never run into before. I have capture something using snapz pro that has been encoded using the animation codec at 24fps and I check this using QuickTime and movie information, but when i import this footage into final cut it shows up as 10fps does anyone know why final Cut is interpreting the footage this way and a solution?
    Mehmet Akten replied 17 years, 11 months ago 3 Members · 2 Replies
  • Tom Wolsky
    September 7, 2006 at 5:58 pm
    Try exporting from QT to a format supported by FCP.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Mehmet Akten
    October 23, 2008 at 12:53 am
    Hi, I was wondering if you found a solution as I have the same problem. I recorded at 30fps with snapzpro and encoded as Prores HQ (1280×720).
    I play the file in quicktime it reports 30fps, duration 2:09, plays really smooth and is the whole duration of what I recorded.
    When I load the file in FCP6, its reported to have the same duration (2:09) but shows 10fps, plays really slowmo, and only plays the first 3rd of what I recorded! and I cannot find a way to change setting. Very strange! Anyone figured this out?
    http://www.memo.tv
