Activity Forums Apple Final Cut Pro Legacy Footage Looks Odd
  • Footage Looks Odd
    Posted by Joseph Wilkins on July 14, 2007 at 10:32 pm
    I have a really important video project that was shot on my HVX200 in 720 p mode.
    I brought the footage into FCP in a 720 24p sequence and edited it… looks great.
    I exported it to a quicktime file using “current settings”
    So then I needed to import it into a DVPRO 50 NTSC to edit it into a SD sequence.
    The problem is, it looks like the fields are off. I looked at the format and it says the footage’s field dominance is set to none, which I think is as it should be, but it still looks off.
    PLEASE help – this is a tight deadline
    thanks in advance
    Jeremy Garchow replied 19 years, 1 month ago 2 Members · 1 Reply
  • Jeremy Garchow
    July 14, 2007 at 10:53 pm
    Try setting your dv50 sequence with a 23.98 frame rate. Then use Cinema Tools to add pulldown if you need to, or if outputting to dv50 tape, let FCP add the pulldown for you on output.
    Jeremy
