Activity Forums Adobe Premiere Pro Footage looks fine in Quicktime, footage becomes stretched in Adobe
  • Footage looks fine in Quicktime, footage becomes stretched in Adobe
    Posted by Nick Izvernari on December 16, 2013 at 10:26 pm
    Hey guys. This may not even specifically be a Premiere Pro issue. I am just trying to figure this out. I have footage that, when I look at the specific .mov file information, says it is 720×486. When I import it into Premiere it looks stretched and when I export it, it also looks stretched. I’ve tried creating sequences that are exactly 720×486 and I’ve tried importing it at exactly 720×486 and it still looks stretched. Here is a picture to illustrate.
    How do I view and export it the same in premiere as I see it play in Quicktime?
    Nick Izvernari replied 12 years, 8 months ago 4 Members · 4 Replies
  • Chris Borjis
    December 17, 2013 at 12:24 am
    Looks like you have some anamorphic sd footage.
    right click the imported file, interpret footage.
    set pixel ratio from 1.0 to 1.2
    It will letterbox it in a 4×3 (720×486) sequence.
    or export it with media encoder set that way or leave it as is the way
    you already have it now but change the pixel ratio for 1.2 on the export screen.
    I’d recommend exporting it as 853×486 with a pixel ratio of 1.0 if this is
    for youtube or vimeo, they don’t usually interpret the pixels properly
  • Ivan Myles
    December 17, 2013 at 2:56 am
    It is possible that Adobe is representing the video correctly. QuickTime does not recognize rectangular pixels and displays everything as 1:1. The 720 width is standard with rectangular pixels in both widescreen and 4:3 formats, but is not used as often with square pixels.
  • Ann Bens
    December 17, 2013 at 11:20 am
    What if you set the monitors in Premiere to fit instead of 100%.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Nick Izvernari
    December 18, 2013 at 8:38 pm
    @Chris – Thanks Chris. That worked and at least solves the problem of viewing it as it was probably meant to be viewed. I will also export with the same settings.
    @Ivan – You are probably right. I think I will just both view it and export it at 1.2:1 ratio.
    @Ann – It looks exactly the same. I only had it on 100% so that people would not suggest I put it to 100% had I shown it at Fit.
