Activity › Forums › DVD Authoring › Footage is “jumpy” and poor quality after burn a DVD with Encore!! :(
  • Footage is “jumpy” and poor quality after burn a DVD with Encore!! :(
    Posted by Esther Casas on October 9, 2012 at 6:00 pm
    Hello everyone! I need help!!
    I am trying to burn a movie into a DVD with ENCORE cs5, and the film comes out “jumpy”, and poor quality. I’ve been reading forums and tutorials and I think is a problem of authoring/ transcoding settings. I am still not sure what settings I could be using to get the best quality DVD, I know is a DVD SD, and my footage is HD…but at least I know that it can look much better, as for now is jumpy and also very poor quality.
    I think my problem must be on settings form final cut pro?
    what I do is this:
    Export Quicktime movie: Apple Pro Res 422 (2048X 1152 size), @24fps 16:9 ratio. i don’t select anything else..
    I import this QT into Encore, and Project settings:
    NTSC Project
    codec: MPEG-2 dimensions 720X480 rate 29.97
    I know my rate is different and it’s not a problem. But do I have to render another type of QT? Also, what settings should I use in the “Export Quality presets?” now I have MPEG-2 DVD, PRESET: DV high quality 23.976 4Mb VBR 2pass
    Does this export settings have to match thje QT exported form final cut pro?
    Thanks to all of you!
    Esther Casas replied 13 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
