Activity Forums Avid Media Composer Footage imported into FCP – now quicktime mov. files not working in AVID
  • Footage imported into FCP – now quicktime mov. files not working in AVID
    Posted by Timothy Lydon on November 23, 2013 at 6:23 am
    Hello,
    I captured a lot of footage from a Canon XHA1 into Final Cut. I took all those files from the capture scratch folder and put them on my harddrive. I imported (using Apple Pro Res) and the screen was all green. I then linked AMA and the screen was also green. Any ideas?
    Timothy
    Chris King replied 12 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Pat Horridge
    November 23, 2013 at 9:04 am
    Open one of the files in quicktime player. You’ll get a warning about not having the right codec. But open the inspector and see what codecs listed.
    My bet is that its a non PC supported codec.
    Pat Horridge
    Technical Director, Trainer, Avid Certified Instructor
    VET
    Production Editing Digital Media Design DVD
    T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
    http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US
  • Shane Ross
    November 23, 2013 at 5:04 pm
    HDV, captured via FCP…is proprietary to FCP. You need FCP to even view it. Convert the footage to ProREs, then send it to Avid.
    Shane
    Little Frog Post
  • Timothy Lydon
    November 24, 2013 at 4:12 am
    Thanks for responding. The problem seems to be with HD footage I captured through FCP. I was able ot import the SD footage no problem but the HD continues to show the green screen when I import, even when I used Apple Pro Res codecs.
    The codecs from the FCP capture are: MPEG-2 Video, Linear PCM, Timecode
    1440X1080 HD
    Any ideas?
    Timothy
  • Shane Ross
    November 24, 2013 at 5:38 am
    As I said…this is the HDV codec that is proprietary to FCP. In order for Avid MC to recognize it, you need FCP…or Compressor…installed on your system.
    Shane
    Little Frog Post
  • Pat Horridge
    November 24, 2013 at 8:36 am
    If that was captured into FCP then its an FCP codec.
    You neef to go back to FCP and media manage it to ProRes first.
    Pat Horridge
    VET
  • Timothy Lydon
    November 27, 2013 at 4:24 am
    Thanks for responding. Does that mean I have to put the file in the timeline and export it as ProRes?
  • Chris King
    December 16, 2013 at 7:41 am
    As far as I know, Avid most compatible format is DNxHD, and it works all the time. If I understand you correctly, you can try to convert your MOV files from FCP to DNxHD codec. I’ve not test yet, but some QuickTime movie and Nikon MOV videos with Avid MC.
