Activity Forums Apple Final Cut Pro Legacy Footage goes dark from AE to FCP, no option to change gamma level in fcp
  • Footage goes dark from AE to FCP, no option to change gamma level in fcp
    Posted by Gabriel Valda on April 25, 2012 at 5:27 am
    Please help, I color corrected a whole movie using after effects and magic bullet,
    The workflow i used was to duplicate and consolidate FCP project ( media manager) then color correct source files in After effects and reconnect back into fcp, all good, the problem is that when i go from after effects to fcp footage gets darker,
    When i export cut from fcp and watch it in quicktime looks fine if i have the “enable final cut studio color compatibility s checked off ” if i check that on footage goes a bit darker again 🙁 , i can see its a 1.8. 2.2 gamma issue, am very confused please help , I need to export final movie and have color llok just as when i was working with after effects, when I go into fcp item properties, then format , there is no option to change the gamma on footage ( source ) gamma level says nothing and no way to change it….
    Juan Salvo replied 14 years, 4 months ago 3 Members · 6 Replies
  • Juan Salvo
    April 25, 2012 at 4:37 pm
    Are you changing codecs? How are you color managing in ae? Overall I don’t recommend using ae as a color correction tool, def not what it’s meant to do.
    online editor | colorist | VFX | BD author
    https://JuanSalvo.com
  • Gabriel Valda
    April 25, 2012 at 8:21 pm
    yeah footage is hdcam originally and changred into prorezhq, had to use AE to be able to use Magic bullet and denoiser since this plugins crash my fcp …
    any ideas or solutions to the gamma problem ?
  • Michael Gissing
    April 25, 2012 at 11:18 pm
    It is important to know how you are actually comparing. In AE were you watching on an external montior via a proper card like Kona, Decklink, Matrox? In FCP are you also monitoring via those cards to a proper monitor? If so and there is a difference then the issue is likely the choice of codec.
    If you are just monitoring on FCP’s viewer or using quicktime on a computer monitor, there are far too many variables to know if there is actually a shift or if it is non standard monitoring.
  • Gabriel Valda
    April 26, 2012 at 12:01 am
    only used computer monitor (apple display) when i watch movie in quicktime (exported from fcp) i looks good when “enable final cut studio color compatibily ” is turned off, when i turn it on then movie (after effects shots only) looks darker (too dark)
  • Michael Gissing
    April 26, 2012 at 1:20 am
    The grade may have been done dark if it wasn’t done with AE using a proper card to an external monitor. If the AE grade was done on a computer monitor set to gamma 1.8 then there is a problem with the grade.
  • Juan Salvo
    April 26, 2012 at 3:01 am
    You cannot evaluate color on a computer monitor.
