Activity Forums Apple Final Cut Pro Legacy Footage from Sony HVR-DR60
  • Footage from Sony HVR-DR60
    Posted by Stewart Stroup on March 2, 2007 at 4:14 pm
    I’m experimenting with my new Sony HDD and V1 and wondering if I’m missing something. I set the HDD to record in the DV format, shoot some test footage, then plug the HDD into the Mac. I drag the DV files from the HDD to another external firewire drive then import them into FCP. They playback with audio in the viewer but not in th sequence. I’ve tried rendering the audio, but no help–just beep, beep, beep. Any thoughts would be helpful.
    Stew
    Stewart Stroup replied 19 years, 6 months ago 3 Members · 3 Replies
  • Paul Dickin
    March 2, 2007 at 4:20 pm
    Hi
    Are the files recorded in .dv DV-stream mode – as used in iMovie?
  • Stuart Simpson
    March 2, 2007 at 4:44 pm
    Sounds like you’re recording the wrong audio rate onto the HDD. Is the audio rate at 44.1khz instead of 48khz?
    -Simmie
    2 G5 – Kona LH
    3 G4s – Cinewave
    1 xbox360, 1 PSP, 1 PS2 & a Gamecube
    https://www.speak.co.uk
  • Stewart Stroup
    March 2, 2007 at 7:07 pm
    The audio rate is determined, as far as I can tell, at the camera and it’s set at 48k. The recording format choices on the HDD are DV raw (the one I’m using) and AVI. Any other suggestions?
    Stew
