Activity Forums Apple Final Cut Pro Legacy Footage from a DSLR and another video camera
  • Footage from a DSLR and another video camera
    Posted by Lawrence Richards on August 16, 2012 at 4:08 pm
    I’m working on a project that necessitates the mixing of footage from a DSLR and an HVX200a. Is it possible to do a multi-cam edit with footage from these two different sources?
    Thank you!
    Larry
    Thank you!
    Larry R.
    Florida
    Lawrence Richards replied 14 years ago 3 Members · 3 Replies
  • Rafael Amador
    August 16, 2012 at 4:40 pm
    No.
    All the stuff must have the same specs.
    rafae
    http://www.nagavideo.com
  • Shane Ross
    August 16, 2012 at 5:03 pm
    Convert both to ProRes with the exact same frame dimensions. This might be tricky as the HVX shoots DVCPRO HD and that it anamorphic. Just make sure that you choose the proper dimensions in Compressor to convert them.
    Shane
    Little Frog Post
  • Lawrence Richards
    August 17, 2012 at 12:32 am
    Darn. Thanks though!
    Thank you!
    Larry R.
    Florida
