Activity Forums Adobe After Effects Footage Freezeframe? Been trying to find an answer forever.
  • Footage Freezeframe? Been trying to find an answer forever.
    Posted by Reynolds Strother on February 17, 2008 at 8:42 pm
    I’ve been looking for an answer to this problem for a few weeks and now I’m admitting defeat. Freeze frame footage.
    The comp is a lineup of different video clips fading in and out in 8 sec intervals. I’m only 1/3 the way into the timeline and having this problem:
    My footage(video) is freezing on a single random frame within its timeline. Sometimes it will flutter between 2 or 3 random frames within its timeline. It only happens to some of the footage videos, not all of them. Sometimes to a few, sometimes to most of them. This problem is apparent when scrubbing the main comp, scrubbing the footage itself, ram previews, and final renders. I assume this is a RAM issue but I have a new Intel MacPro, two 2.66 dual core, 6gigs of ram, AE CS3. I thinks it’s RAM because when I clear all caches it will “sometimes” fix the issue, until it happens again 10 sec later. I’m working on I’ve tried my AE preffs at default for 2gigs of ram, and with 6gigs. The footage is small in size and there aren’t many effects being used at all. Still happens when all effects are turned off.
    Here is some more info about the comp:
    -3 min comp, 30fps, 1200×720
    -all footage is QT video at 30 fps
    -After no fix with proxies, I’ve force fed proxies(no fix), then tried re-rendering all video into half res, med quality, NEW files, All less than 50mb with most less than 20mb.
    -RECREATED the entire comp, with better efficiency and the new smaller videos.
    Still happening and I’m at wits end. The project is nearing deadline. I’m getting so frustrated with this. Need help resolving this really bad.
    Jeremy Mullen replied 17 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • Darby Edelen
    February 18, 2008 at 12:12 am
    [Reynolds Strother] “-all footage is QT video at 30 fps “
    Can you give more information about what codec the footage is compressed using? QT is only a container format.
    You can also experience problems like this when using some effects. If a frame has already been rendered in the timeline and you make a change to the effect’s properties, then the already rendered frame may not be purged from memory.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Reynolds Strother
    February 18, 2008 at 4:09 am
    All of my footage is QT Photo JPG and I’ve tried using H.264 and Mpeg-4. All had the same problem.
    I’m on QT 7.4.1 now. This problem was present before the QT 7.4 fiasco so I’m sure it isn’t a version issue.
  • Reynolds Strother
    February 18, 2008 at 7:17 pm
    That explains the strange behavior. What are some better choices for codecs, and thanks for the help.
  • Darby Edelen
    February 18, 2008 at 10:43 pm
    [Reynolds Strother] “That explains the strange behavior. What are some better choices for codecs, and thanks for the help.”
    Photo JPEG is perfect… But I thought you had already tried that, at least that’s what I read when you said:
    “All of my footage is QT Photo JPG and I’ve tried using H.264 and Mpeg-4. All had the same problem.”
    I suppose I should’ve recommended you never use H.264 and MPEG-4 as well, but I read that as though you had tried Photo JPEG (which should not have the same problems as H.264/MPEG-4) so I assumed that something else was going on in this case.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Reynolds Strother
    February 19, 2008 at 7:04 pm
    I just don’t understand what is going on with this comp. My computer should be able to handle it so I can’t blame it on the processor or the ram. The files are small videos, all Photo JPG.
    I’m going to lose it on this one. Usually I feel like this for the two hours it takes to get an animation looking right or to adjust something in 3D so it stops overlapping an object it should be behind. This situation is lingering on forever and no matter how long I look for someone who has experienced this, I that I’m the only one on earth. This must be a top secret version of AE from Adobe designed to render it’s user into a twitching ball of frustration.
    Maybe I should kick the computer with the side of my foot. Seems to work on old lawnmowers.
    HELP!
  • Jeremy Mullen
    August 30, 2008 at 8:03 pm
    I imagine it’s a bit late for consolation on your project, but I can say I’ve actually just run into this myself. I had XDCAM EX footage I was using for greenscreening, and then planned to bring the keyed shots into more complex compositions. To save time (I thought) down the road, I did my keys and then prerendered the key comps. Lo and behold, when I looked at the prerenders, half of them were freeze frames. It was weird, because it was not consistent – some of the prerenders worked (they moved) and others were still. When I went back to look at the comps I had made the keys in, again, some of them moved, but all of a sudden, others wouldn’t refresh – the footage itself had become a freeze-frame. When I went out to the footage viewer, it was fine – it moved. As soon as I dragged it into a comp and applied any effect or transformation or mask, it became a freeze-frame. What’s weirder, is that the footage had been moving when I made the keys (I needed to animate masks, so I know things were moving then), so it wasn’t always this way. Things just started going crazy when I did some work, went away from the application. and came back and did some more work.
    So I found this thread and suspected codecs, and I’ve now gone out of AE, converted my XDCAM EX footage into None-compressed, and brought the new clips into my AE keying comp. It works. For now.
    I sort of suspected perhaps my computer went to sleep during the prerenders or just while AE was running, and I’ve definitely noticed CS3 hates when it is open and my computer goes to sleep. I’ve had numerous crashes and freezes (Mac OSX 10.5.4) from waking a computer while AE was still open. So there’s a couple of potential culprits.
    Reynolds, any discoveries at your end in the meantime? Does this sort of conversion help your stuff? You’re right – this must be happening to SOMEBODY else out there.
  • Dan Walsh
    February 16, 2009 at 7:30 pm
    I realize this thread has been dead for awhile, but I’m experiencing this same problem. My footage was shot on HDV, but I transcoded to ProRes 422 before importing into AE. Comp is 1280 x 720, square pix. It almost feels like a cache issue- it will freeze on some frame and not update no matter where I am in the timeline. Ram previews will display a few random frames (not in sequence). It renders like this as well. I’ve tried adjusting the secret prefs to clear the cache, no luck. sometimes if i “purge all” it will update and display the correct frame, but that only lasts for a second before it freezes again. I’ve only seen this problem with HD footage.
    has anyone had any luck fixing this?
    my specs are macpro 2 x 3ghz quad, AE CS3, and QT 7.5
  • Jeremy Mullen
    February 16, 2009 at 7:35 pm
    Ultimately I reinstalled AE and I haven’t had a problem since. Not the answer most people want to hear, but at least it did the trick.
