Activity Forums Adobe After Effects Footage “flicker” with RAM preview and render
  • Footage “flicker” with RAM preview and render
    Posted by Martin Banks on May 8, 2013 at 5:51 am
    I have some footage to edit that was shot on a Canon 60D at 25fps.
    I have used AE CS6 to put together the clips. There are about 14 precomps in the main composition.
    When I RAM preview the playback, and also when I render out the video as an avi or H264, there appears to be a kind of flicker to the footage.
    I wouldn’t necessarily call it a flicker. There is a horizontal separation in the alignment of the footage as it pans. If that makes sense?
    I’m on a Win7 64bit machine with 8GB RAM.
    I’m guessing there is some kind of effect I can add to remove the flicker? It almost reminds me of exporting Canon footage from Premiere without using a progressive field order when exporting. Is there something in AE that will sort it?
    Any help is grately appreciated.
    Regards,
    Martin.
    Martin Banks replied 13 years, 4 months ago 2 Members · 2 Replies
