Activity › Forums › Adobe Premiere Pro › Footage double exposure error
  • Footage double exposure error
    Posted by Mathew Smith on February 19, 2020 at 9:51 am
    Hi there,
    Today I was asked to cut some footage together with Premiere Pro of an interview, when checking the footage before import all the video looked good with no effects added, however once I’d imported it a strange effect seemed to be applied, almost a double exposure effect. I exported the footage and the error remained. I have not applied any effects to the video so I am not sure what has caused this, have I missed something or is it something corrupt with the original video? Just for background, I’m normally a graphic designer so I’m a bit of a Premiere amateur so apologies if this is a simple fix.
    Here are some screenshot examples
    Before import:
    After import:
    Thank you for any help you can provide
    Todd Perchert replied 6 years, 7 months ago 3 Members · 2 Replies
  • Vince Becquiot
    February 19, 2020 at 6:42 pm
    Select the clip that has the issue, and make sure the blend mode is set to “normal” the in the effects conrol panel.
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Todd Perchert
    February 20, 2020 at 4:58 pm
    What are the specs of your original footage? File type, codec, fps… and did you import directly or go through Media Browser to import?
