Activity Forums Adobe After Effects Fonts disappear from AE 6.5.1 list, but (mostly) OK in AE 7
  • Fonts disappear from AE 6.5.1 list, but (mostly) OK in AE 7
    Posted by Steve Roberts on May 31, 2006 at 2:23 am
    (OS10.4.4, G5 dual 2 GHz, 2.5 GB RAM)
    This is odd. After installing AE 7, my 6.5.1 projects (old and new) can’t access Trajan Pro or Adobe Garamond Pro. I get the “missing layer dependencies” error, and the needed fonts show up grayed-out, in brackets at the bottom of the font list in AE.
    However, when open a problematic project in AE7 for the first time, those fonts now appear exactly where they should be, and I can use them as expected.
    I also see the same problem when both apps have the same project open. AE 6.5.1 bad, AE 7 good.
    In a possibly-related occurrence, the icon for each font (in the font library in the finder) has changed to a sort-of blank file icon, reading zero K, not 32K or so, and they’re listed as “documents”, not fonts. Other zero-K missing font families are Stempel Garamond, Classic Script MN and Helvetica Neue. I can see Truetype fonts and PS fonts normally. I now see that AE 7 has access Helvetica Neue, but not Stempel Garamond and Classic Script MN.
    I’ve searched the COW, but haven’t found an answer to this specific problem.
    I’ve relaunched and restarted.
    Sorry, I don’t know where these fonts came from over the years. I have PS, Illustrator, AE and the FCP Suite.
    This only started since installing AE 7.
    Any ideas?
    Steve Roberts replied 19 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
