Activity › Forums › Adobe After Effects › Font square problem
  • Corey Curry
    July 29, 2018 at 2:35 pm
    It’s probably your monitor. I can’t see any squares in the fonts. Probably want to calibrate your monitor https://www.lagom.nl/lcd-test/
  • Onur Uygur
    July 29, 2018 at 4:34 pm
    I checked my monitor. All is good with that. The problem is, as you can see F is so straight there is no problem with that. But A is not. There are a lot little square in the A. Im sometimes seeing this problem sometimes not? Do you have any idea why is that?
  • Onur Uygur
    July 29, 2018 at 9:06 pm
  • Corey Curry
    July 29, 2018 at 10:38 pm
    Are you talking about the pixels? Is the quality set to quarter?
  • Jim Scott
    July 29, 2018 at 11:07 pm
    You’ve either got the resolution set to something less than Full, as Corey asked, or you have magnified the Comp window above 100%.
