Activity › Forums › Adobe After Effects › Font size problem between Final Cut and AE
  • Font size problem between Final Cut and AE
    Posted by Robert Kornstein on March 21, 2014 at 1:41 am
    I received font specifications for subtitles/lower thirds from a client who was scrubbing through the video in Final Cut over the phone, as I followed along with a Vimeo-hosted video.
    I imported the video into After Effects and used the font sizes they gave me, but the fonts came out way too small, about 4X smaller than they should be on-screen.
    What could be causing this issue? Are the font sizes measured differently in Final Cut or something?
    Hans Wijnen replied 12 years, 6 months ago 2 Members · 1 Reply
  • Hans Wijnen
    March 21, 2014 at 4:22 pm
    The problem is caused by difference in resolution (probably). Just use the tip above and you should be fine 🙂
