Activity › Forums › Adobe After Effects Expressions › Font family control thru all compositions in the project
  • Font family control thru all compositions in the project
    Posted by Khalil Chikh on November 7, 2021 at 8:35 pm
    Hello,
    I am creating a calendar events video for a client.
    I am checking if I can use a font control in my main comp to change all the numbers font family, font size, etc. in my compositions at once, like I did for color control.
    I hope there is a way to do that.
    Thank you
    Khalil Chikh replied 4 years, 10 months ago 2 Members · 2 Replies
  • Tomas Bumbulevičius
    November 8, 2021 at 12:43 pm
    Hey Khalil, there is definitely a way to control these through expression – but you must ensure that all the texts are linked to your “controller” text.
    There are two main options:
    1. You do this through essential graphics panel;
    2. You do this through expressions.
    Depending what flexibility you are going to offer for a client, that will provide a path to follow. However, be aware that allowing such things like font sizes change, requires additional logic double check, in case if design overbleed its boundaries.
  • Khalil Chikh
    November 8, 2021 at 2:12 pm
    Hey Tomas,
    Thank you for your kind reply.
    I kind of solved it yesterday after some searches in such a way of expressions, but I hope there is a better way.
    I typed an expression on all the text layers in the project to follow one of the text layer style.
    The expression on all the layers Source Text is:
    comp(“Calendar Day Box 35”).layer(“sunday”).text.sourceText.style;
    So (“sunday”) is one of the layers in the composition called (“Calendar Day Box 35”)
    So whatever I make changes in Character pallet in (“sunday”) layer it will be change on all other text which has this expression.
    The url was: (https://helpx.adobe.com/after-effects/using/expressions-text-properties.html) at (Main text layer) section.
    Thank you again for your replay 🙂
