Activity › Forums › Adobe After Effects Expressions › following position x
  • following position x
    Posted by Josh Holdens on September 18, 2011 at 1:25 am
    Alright here’s what I’m trying to accomplish. I want to be able to follow a given property(in this case position), but specifically the x or y position. I thought it would be as easy as setting a variable then adding the valueAtTime expression, but I’m definitely missing something…. I saw the delay expression but I’m still unsure how to apply that in this case.
    x = thisComp.layer("White Solid 2").transform.position[0].valueAtTime(time - 1);
    y = value[1];
    [x,y]
    Josh Holdens replied 15 years ago 2 Members · 2 Replies
  • Dan Ebberts
    September 18, 2011 at 2:58 am
    You just have the array indexing for x in the wrong place. Try it this way:
    x = thisComp.layer(“White Solid 2”).transform.position.valueAtTime(time – 1)[0];
    y = value[1];
    [x,y]
    Dan
  • Josh Holdens
    September 19, 2011 at 11:29 am
    Great big thanks, I was completely stomped.
