Activity › Forums › Apple Final Cut Pro Legacy › Follow Up To G5 Will Not Power Up
Posted by Bill Carnicelli on February 16, 2006 at 6:59 pmJust FYI for any one interested in my earlier post. The dual 2.5 G5 is toast! Apparently the cooling system failed causing the processors to overheat. Which caused the power supply to fail when I tried to power the machine on. My tech recommended not repairing the machine. So I
David Bogie replied 20 years, 7 months ago 5 Members · 6 Replies -
Debe
February 16, 2006 at 7:25 pmWas it still under warranty? Apple Care? Almost any Dual 2.5 G5 should still be under Apple Care! Where’s this tech from?
debe
Bill Carnicelli
February 16, 2006 at 8:14 pmI machine was purchased in the fall of 2004 and is out of warranty. Apple does not sell the Apple Care extended warranty in Florida. The tech is from my local Apple reseller and they are an Apple certified repair center.
Bill Carnicelli
Debe
February 16, 2006 at 8:23 pmWow, that’s too bad.
Looks like you do indeed have yourself a doorstop!
Sorry!
debe
Ben Oliver
February 16, 2006 at 8:27 pmsomething like that happened to my dualcore g5 here at work, luckily it happend 2 weeks after i opened the box!
Michael Peele
February 16, 2006 at 9:18 pmmod the g5 case to hold an intel board, then run a cracked intel build of os x… 🙂
no one will know the difference…seriously though, if your HD’s are the same size, you may want to mirror them.
mike
David Bogie
February 16, 2006 at 9:50 pmwe are all sorry for your loss. It’s rare that a Mac dies in flames like that but it does indeed happen.
When you have some spare time, take a few hours to search the Web for G5 case hacks. People have done some incredible stuff with these elegant boxes from stereo racks to making beer coolers to making a huge iPod dock.
bogiesan
