follow the leader with delay – but on a curvy shape
Hi
I have been using after effects for several years nd usually can sort of fudge my way through expressions (without truly understanding what i am doing). but today I can´t seem to figure out how to do this one.
I have a set of yellow squares which i want to flow in a “follow the leader with delay” type manner, ending up forming a cloud shape (which is the logo of the company). I am animating the first layer using a mask shape which I then copied into it’s position properties and selected “orient towards line¨.
Usually when doing a “follow the leader” type animation i use this expression:
thisComp.layer(A).position.valueAtTime(time-.1)
and to displace the next layer i add a -50 or whatever to the end. But this is a curvy shape so if i just put -50 it goes off the path….
In the picture i have just manually placed them to give you an idea…
https://www.annagreve.com/example.jpg
I have been staring at this for ages, I can´t figure it out!
thanks! 🙂 anna
