Activity Forums Adobe After Effects Follow the actor with a light around the objects
  • Follow the actor with a light around the objects
    Posted by Samy4movies on August 27, 2007 at 11:01 pm
    Hi anyone there,
    How can I follow a path around and object with a light then highlighted all at once?
    I watched the tutorial for outlined the actor by Andrew Krammer, cool, but How can I light in a sequence of following a path around it?
    Thanks for any help.
    I am doing some effects for my 15TH birthday presentation with some effects that I found in this great creativecow site.
    Thanks to all of you!
    Samy
    Samy4Movies
    Samy4movies replied 19 years ago 2 Members · 2 Replies
  • Malcolm Desoto
    August 28, 2007 at 5:27 am
    Could you be a little bit more specific? I don’t quite understand what you are trying to achieve.
  • Samy4movies
    August 28, 2007 at 6:30 am
    Thanks first of all.
    Let see if I can explain it.
    I have and object, and I want to have the outline around it. Then I want to see like spark ignited like the mission impossible but in this case is following the object. I don’t want the whole object highlighted at once but a spark going from one point to go all around.
    See if you find my idea clear. Thanks
    I saw it once but Iguess the website is not valid anymore so I can not show you what I mean.
    Thanks in advanced.
    Samy4Movies
