Activity Forums Adobe After Effects Expressions follow rotation and postion tç get a spiral movement for particals
  • follow rotation and postion tç get a spiral movement for particals
    Posted by Tielman Dewaele on December 20, 2013 at 8:06 am
    hey they,
    i want to create a spiral path on a for some particals.
    I figured i parent a Null(1) thats follows a null(1) that moves on Z and rotates on z. Moving Null(1) over time a bit would then create somewhat spiral movement.
    The particals would then follow the position of null(1).
    However with parenting this isnt posible.
    How would i achieve this with expressions. The anchorpoint needs to be on the spot where the null(1) is. Not on null(2).
    A light with be linked to the postion of null(1) as well.
    I read about a couple of expressions like this one.
    https://ae.tutsplus.com/articles/news/spirals-and-after-effects/
    But this isnt really want i want for control.
    See picture
    MacPro/PC
    Production Premum cs 5.5
    FCP 7.0 studio
    C4d R11,5 & R14
    Kevin Camp replied 12 years, 8 months ago 4 Members · 8 Replies
  • 8 Replies
  • George Goodman
    December 20, 2013 at 3:19 pm
    What particle producer are you using?
    “|_ (°_0) _|”
    Sincerely,
    George
  • Tielman Dewaele
    December 21, 2013 at 5:28 pm
    trapcode particular
    MacPro/PC
    Production Premium cs 6
    FCP 7.0 studio
    C4d R14
  • Tielman Dewaele
    December 22, 2013 at 10:51 am
    nobody?
    MacPro/PC
    FCP 7.0 studio
    C4d R14
  • Perry Kroll
    December 22, 2013 at 10:27 pm
    I think what you’re asking for is to get the position of a null that is a child of another null.
    Try this.
    Of course you may need to adapt for Z to make it work for Particular, but that’s at least a start.
    lay = (pickwhip the child null layer) ;
    pos = lay.toWorld( lay.anchorPoint);
  • Tielman Dewaele
    December 23, 2013 at 11:00 pm
    thanks perry but no i dont think so.
    The null 1 should follow the null 2 like it would be parented.
    But particular doesnt work with the parenting.
    So null 1 should follow the anchorpoint of null 2, so it rotates around the null 2(around its anchorpoint). But the anchorpoint of null 1 should stay as is(so i can link particular to that position)
    T
    MacPro/PC
    FCP 7.0 studio
    C4d R14
  • Tielman Dewaele
    December 23, 2013 at 11:06 pm
    the null 1 should all move seperatly
    MacPro/PC
    FCP 7.0 studio
    C4d R14
  • George Goodman
    December 23, 2013 at 11:14 pm
    I don’t really know what you’re trying to do with this spiral.
    What’s wrong with doing it like this?
    https://ae.tutsplus.com/tutorials/motion-graphics/quicktip-creating-circular-and-spiral-motion-paths/
    “|_ (°_0) _|”
    Sincerely,
    George
  • Kevin Camp
    December 25, 2013 at 6:50 am
    parenting should work just fine, but you need to use a light as an emitter.
    create a new light, name it ‘Emitter’, parent the light to the null and then set particular’s emitter to be a light (it will automatically use the light named Emitter.
    if you need the emitter to be a point, set the light to be a point source. if you need the emitter to be directional, set the light to be a spot light.
    you could also choose to use a 3d layer as the emitter. just create a solid that is the size you want for the emitter, make it 3d, parent to the null and then choose ‘layer’ for emitter type and select your 3d solid.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
