Activity Forums Adobe After Effects Follow line mask
  • Follow line mask
    Posted by Matthew Barber on March 23, 2009 at 9:30 pm
    I have a letter from the alphabet that i need to write on screen how would i make an animated mask start point and end point at the bottom of a letter. Can someone help????
    Cheers
    Dave Johnson replied 17 years, 6 months ago 2 Members · 1 Reply
  • Dave Johnson
    March 24, 2009 at 10:52 am
    If I understand correctly what you’re asking, just select the mask vertex you want to be the start & end point and go to Layer > Mask and Shape Path > Set First Vertex.
    The default first vertex is the first one made when the mask was drawn and is indicated by a larger square than the other vertices. The currently selected vertex is indicated by a filled square instead of the outlined squares the other vertices have.
