Activity › Forums › Maxon Cinema 4D › Fog Anti Alias Problem
  • Fog Anti Alias Problem
    Posted by Maarten Thomassen on June 4, 2011 at 10:34 am
    Hi there.
    I’m a novice user of Cinema 4d. I have this scene set up where i move a model
    trough a cube which is equipped with a material with only the fog parameter set.
    Whenever I render the image, the model doesn’t Anti-Alias (i get jagged edges).
    When I turn off the cube (and thus the fog) the model does Anti-Alias.
    How can I fix this?
    Also, does anyone know of a better way to render fog in stead of just
    slapping a fog material on a cube? I also have a volumetric light, but that gives
    almost the same effect really. Is there a way to render fog with “impurities” perhaps?
    Adam Trachtenberg replied 15 years, 4 months ago 3 Members · 8 Replies
  • 8 Replies
  • Tim Shetz
    June 4, 2011 at 3:50 pm
    You could add noise on the noise tab of your volumetric light. Nice thing is it can be animated as well.
    __________
    Tim Shetz
    c4dtraining.com
  • Maarten Thomassen
    June 4, 2011 at 3:52 pm
    Thanks for your reply.
    Yes i can add noise, but there are only 4 noise options and you can’t really adjust the noise like
    when you are adding it to, say, the color layer of a material.
    Also, this isn’t my main issue, but the Anti-Alias thing is, any idea on that?
  • Tim Shetz
    June 4, 2011 at 4:06 pm
    In your render settings, do you have your anti-aliasing set to BEST?
    As for adjusting the noise, there are plenty of settings there to adjust the noise. Are you going for the look of fog, or something else?
    __________
    Tim Shetz
    c4dtraining.com
  • Maarten Thomassen
    June 4, 2011 at 7:38 pm
    Yes, that was the first thing i tried fiddling with 🙂
  • Tim Shetz
    June 5, 2011 at 12:27 am
    Can you post a file for me to take a look at?
    Hard to tell what could be going on without seeing it.
    __________
    Tim Shetz
    c4dtraining.com
  • Adam Trachtenberg
    June 5, 2011 at 4:40 pm
    If it’s not working with the default Best AA you’ll have to bump up the Min/Max values. Try 2×4 and go up from there (4×4, 4×8, etc.).
    If the fog material and area lights aren’t working you might try experimenting with Pyrocluster (if you have it).
  • Maarten Thomassen
    June 5, 2011 at 4:43 pm
    Thank you all for your relies. However I have already experimented with ALL settings in the AA tab and they didnt do anything.
    As for pyrocluster, I have it and i fiddled around with it but it takes hours to render
    and didn’t really make a nebula the way i wanted it, probably because I don’t have much
    expereicne with it. Do you know any good tuturials that cover Pyrocluster?
  • Adam Trachtenberg
    June 5, 2011 at 7:49 pm
    I don’t know of any PC tutorials, but in terms of speed the key settings are on the material that goes on the environment object (world step size and ray trans. limit).
    I don’t know why the AA settings aren’t working for you. They work here.
