Activity Forums Zaxwerks Focal point of AI object
  • Edward Wu
    March 2, 2009 at 7:03 pm
    The focal point of Illustrator objects is determined by the center point of the objects. If each object is separated when they are brought into ProAnimator/Invigorator Pro, then the focal point is the center of each object. If your objects are all grouped together, then the focal point is the center point of all the objects combined. You can find the focal point in Illustrator by selecting all the objects, and look at the center point of the bounding box.
    Best,
    Edward
